Achizitie Grande Punto...merita?
Scris 28 iulie 2006 - 08:40
rog un moderator sa mute topicul
Scris 28 iulie 2006 - 08:52
2.nu are cine sa-l mute.
Scris 28 iulie 2006 - 08:57
Scris 28 iulie 2006 - 09:48
bleunightdanger, ai putea posta ceva la subiect, macar o data? te rog frumos sa iti vezi de treaba ta
EDIT: Topicul era la Masina mea, intre timp a ajuns unde trebuie, asa ca va agitati degeaba
[Edited on 28-7-2006 by MikeTekRacing]
Scris 28 iulie 2006 - 10:14
tu (cel putin deocamdata) nu ai aceste obligatii.
nu ma bag in seama aiurea (ca tine) ci incerc sa mentin forumul ordonat si curat, semnaland ce vad in neregula. intra in atributiile mele, asa ca te rog ca pe viitor sa te abtii de la bagari in seama.
multumesc
Scris 28 iulie 2006 - 11:55
Masina merita toti banii evident, mai ales 1.3 90cp care ieri m-a impresionat prin silentioitate. Am mers cu Corsa de 70cp si am fost impresionat cum se duce. 90cp vor face mai mult...1.4 80cp e o solutie economica, dar dinamica va ave de suferit ceva. Poti sa astepti ceva vreme pentru 1.4 16v de 95 cp care este excelent.
Scris 28 iulie 2006 - 10:37
Scris 28 iulie 2006 - 11:52
[Edited on 28-7-2006 by the1]
Scris 30 iulie 2006 - 05:24
Scris 30 iulie 2006 - 07:19
Once the car goes sent (for example in highway) can be an pleasant motor to use. Comparativily it is it less in city than in highways, because until 2,000 rpm gives little acceleration (something that also happens to him to the version of this same motor with 75 CV) and it costs to him to gain speed.
In normal conditions, the Point does not leave easily from unemployed, and to do it (sometimes the urban circulation requires it), it is necessary to make slide the clutch more of the normal thing. A Celebration or a C3 with 1,6 motor Diesel engine (with 90 and 110 CV respectively) or the 1,9 TDI of 101 CV of the more pleasant Pole is something to use to a low regime. This version cannot have the assistant of starting in hill "Hill Holder".
According to our measurements of acceleration and recovery, the Great Point is in an intermediate place between a Fiat previous Point with 1,3 motor 16V Multijet of 69 CV (that is continued selling) and the new Renault 1,5 Clio dCi 106 CV or that of the new Volkswagen Pole 1,9 TDI 101 CV. In any case, a slow car for its power and size cannot be considered.
This version of 90 CV of power has a manual gear box of six speeds. Sixth km/h is a very long march (49 each 1,000 rpm) and that is only really useful to roll by cleared highways, although with her also slopes little pronounced without losing speed can be ascended whenever the car does not fall below about 100 km/h.
Although it does not serve for certain conditions of use (for example with dense traffic with changes of rate), because the capacity of answer of the motor with this march very is limited, one sixth that long I believe that it is not a problem. He is always better to have the one not to have it, and if much acceleration makes lack, there are available five shorter speeds. In addition, the change of marches works well (better than the one of five marches of the Diesel version of 75 CV) and is fast. One sixth of relief always comes well to lower the noise; normally also it lowers to the consumption and the wearing down of the motor.
The Point 1.3 Multijet 90 CV (although its denomination he is 1.3, in fact is 1.2, because cm3 has 1,248) difference technically of the version of 75 CV in which it has a variable turbocompressor.''
km77
Scris 30 iulie 2006 - 11:36
Scris 31 iulie 2006 - 10:52
Scris 31 iulie 2006 - 06:23
Scris 01 august 2006 - 11:14
