#2276
Scris 20 ianuarie 2010 - 04:15
Scris 20 ianuarie 2010 - 05:31
#2278
Scris 20 ianuarie 2010 - 06:29
#2279
Scris 20 ianuarie 2010 - 08:25
The good: Great range and signal penetration; integrated print, media, FTP, and Webcam servers; can support multiple USB devices simultaneously.
The bad: Bulky and impractical design; buggy Web interface; confusing instruction if you're trying to figure out the special USB features; throughput at close range could better; no Gigabit Ethernet.
The bottom line: We like the Asus WL-500W for its wealth of unique features and its strong signal at long range, but its short-range throughput is substandard and there's no Gigabit Ethernet support. This is a good choice only for advanced users who will take advantage of some of router's USB features and aren't afraid to wade into those waters without help.
la rele eu n-am avut neplaceri absolut deloc cu el. merge non-stop de cativa ani.
Aside of the regularly goodies including a firewall, encryption, QoS, and a print server, the WL-500W also has a built-in FTP server, a file server, and a Webcam server, as well as the ability to download files by itself. On top of being a Draft N wireless router, the WL-500W can also do much that a basic server can do. It's not without its drawbacks, however. For one, we're not thrilled with the design, and its Web interface could be more intuitive.
nu stiu ce pana mea se asteapta astia de la interfata, dar mi-e mi se pare super intuitiva.
Scris 21 ianuarie 2010 - 02:44
#2281
Scris 21 ianuarie 2010 - 02:51
Scris 21 ianuarie 2010 - 09:20
Aceasta postare a fost editata de VIPER: 21 ianuarie 2010 - 09:20
Scris 21 ianuarie 2010 - 09:24
#2284
Scris 21 ianuarie 2010 - 09:56
Scris 21 ianuarie 2010 - 09:59
#2286
Scris 21 ianuarie 2010 - 10:02
Enervanta e insa alta treaba, de cateva zile nu mai pot intra pe Gmail ca mi se blocheaza Vulpea de Foc. Am tot citit pe net de problema, nici o rezolvare concreta. Am pus si 3.6 aparut azi, nimic... Si imi e asa o sila sa folosesc IE pt asta...
Scris 21 ianuarie 2010 - 10:14
#2288
Scris 21 ianuarie 2010 - 10:23
Scris 21 ianuarie 2010 - 10:32
#2290
Scris 21 ianuarie 2010 - 10:35
la mine merge fara probleme.
Scris 21 ianuarie 2010 - 10:36
Aceasta postare a fost editata de VIPER: 21 ianuarie 2010 - 10:36
Scris 21 ianuarie 2010 - 10:39
#2294
Scris 21 ianuarie 2010 - 11:07
Pentru SMTP la RDS trebuia doar sa trimiti cererea .. scrie si undeva pe site la ei chestia asta dar cum au 8-9 site-uri pentru fix aceleasi servicii si deloc actualizate (am observat ca prefera sa faca alt site decat sa-l actualizeze pe cel vechi) nici nu ma mira ca nu mai stiu unde am citit informatia respectiva.
#2295
Scris 21 ianuarie 2010 - 11:22
Coana roza ....
Aceasta postare a fost editata de Relu: 21 ianuarie 2010 - 11:22
#2296
Scris 21 ianuarie 2010 - 11:39
Surpriza, RDS mi-a acceptat cererea de deblocare SMTP! Daca vinovati sunt Relu sau Adytzu, le multumesc, daca nu, aplauze pt RDS ca mi-au inteles corect doleanta.
Eu nu am facut nimic, bre...de ce dai in mine?
Ti-am spus doar ce trebuie sa faci si atat. Inseamna ca le-a venit mintea la cap celor de ia ierdeiesh...ceea ce e de laudat. Din experienta, insa, blocheaza de pe router portul 25 sa nu din LAN spre WAN. Nu de alta, dar daca prinzi un troian si incepe ala sa trimita SPAM, iti blocheaza RDS portul la loc instant...si fara sa te anunte.
#2297
Scris 22 ianuarie 2010 - 08:40
Scris 25 ianuarie 2010 - 03:30
am pus in stanga linkuri ( bookmarks ) catre cateva siteuri.
dar de fiecare data cand dau click pe unu de ex, mi-l deschide in aceeasi fereastra, peste cel precedent.
doar daca ii dau click dreapta, si open in new tab atunci mi-l deschide intr-un tab nou.
cum pot face ca fiecare bookmark sa mi le deschida in taburi separate?
#2299
Scris 25 ianuarie 2010 - 03:32
#2300
Scris 25 ianuarie 2010 - 03:37
acuma am luat si eu firefox
... cu cit ???
