2014 Mercedes C-class ( Baby S )
39 replies to this topic
#1 ska
Scris 11 februarie 2014 - 10:52
Mercedes-Benz has finally taken the wraps off the new C-Class, following a multitude of leaks and fully revealing spy photos.
The C-Class is no longer Mercedes-Benz's entry-level sedan offering as this role has been at attributed to the CLA. As a consequence, the German marque had to distance the C-Class from the A-Class-based sedan and as a result the W205 generation has grown in size since it is 95mm longer (at 4686mm) and 40mm (at 1810mm) wider than its predecessor, while height stands at 1442mm. 80mm of the added length is in the wheelbase which now stands at 2840mm and the cargo capacity has been increased to 480 liters.
From a design point of view it doesn't bring anything new to the table compared to its bigger E-Class facelift and all-new S-Class brothers yet it does look significantly more premium than the outgoing model. It features a long hood and shorter overhangs along with a narrower glasshouse and more flowing lines. Overall, the 2014 C-Class looks more modern and will likely attract additional younger customers without having a negative effect on the usual C-Class clients.
Back in October we saw the interior cabin which looks considerably more luxurious thanks to the use of more premium materials and a wraparound dashboard with three circular air vents. There are less buttons on the dashboard as many of them have been replaced by a free-standing screen sitting on top of the dashboard which can be accessed via a rotary controller offered as standard. There's an optional touchpad which has just about the same functionality that you get on a smartphone.
The 2014 Mercedes-Benz C-Class rides on the modular MRA rear-wheel drive architecture and is up to 100 kg (220 lbs) lighter than the outgoing model. As a result of this significant diet, fuel consumption has been reduced by 20 percent without affecting performance. The vehicle also has a lower center of gravity which should result in a sportier handling experience.
It will be the first vehicle in this segment to be offered with air suspension in the form of an optional self-leveling AIRMATIC which is electronically controlled on both axles and features continuous variable damping. The standard steel suspension comes with a selective damping system offered in three modes: comfort, comfort with sportier character and a sports suspension which lowers the car by 15mm.
Upon launch it will be offered with three engines, starting with the C 220 BlueTEC packing a 2.2-liter 4-cylinder diesel rated at 170 HP (125 kW) and 400 Nm (295 lb-ft) of torque. It will do 0-62 mph (0-100 km/h) in 8.1 seconds and will have a fuel consumption of just 4 liters / 100 km (58.8 mpg US or 70.6 mpg UK) with CO2 emissions of 103 g/km.
Next is the C 180 model with a 1.6-liter gasoline engine delivering 156 HP (115 kW) and 250 Nm (184 lb-ft) which will be enough for a 0-62 mph run in 8.2 seconds. Fuel consumption will stand at 5 liters / 100 km (47 mpg US or 56.4 mpg UK) with corresponding CO2 emissions of 116 g/km.
There will also be a more powerful C 200 model with a 2.0-liter outputting 184 HP (135 kW) and 300 Nm (221 lb-ft) of torque. The engine will grant the car with a 0-62 mph run in 7.5 seconds and a fuel consumption of 5.3 liters / 100 km (44 mpg US or 53.2 mpg UK), while CO2 emissions will be of 123 g/km.
Shortly after the new C-Class will go on sale, Mercedes-Benz will introduce a 1.6-liter diesel that will be available with 115 HP (85 kW) / 280 Nm (206 lb-ft) and 136 HP (100 kW) / 320 Nm (236 lb-ft). In addition, the car will also be offered with a 2.2-liter diesel with 115 HP (85 kW), 204 HP (150 kW) and also with 170 HP (125 kW) in the BlueEFFICIENCY Edition.
Other engines on the way are five 4-cylinder gasoline motors with output ranging from 156 HP (115 kW) to 238 HP (175 kW). In addition, there will be a C 300 BlueTEC HYBRID encompassing a 4-cylinder diesel with 204 HP (150 kW) working together with a 27 HP (20 kW) electric motor which will provide the car with a fuel consumption of just 3.9 liters / 100 km (60.3 mpg US or 72.4 mpg UK).
Depending on engine choice, the 2014 Mercedes-Benz C-Class will feature a newly developed 6-speed manual gearbox or a 7G-TRONIC PLUS seven-speed automatic transmission. Optionally available will be the firm's 4MATIC all-wheel drive setup and various safety systems such as Active Parking Assist, Adaptive Highbeam Assist Plus and Traffic Sign Assist with Wrong-Way Alert.
Already available on order, the new C-Class starts at 33,558 EUR in Germany for the C 180 model. Opt for the C 200 model and you will have to pay 36,414 EUR while the C 220 BlueTEC is priced at 38,675 EUR.
ceea ce mi se pare interesant e ca va avea un rezervor de doar 40-45L... i mean... wtf?!? :)
Aceasta postare a fost editata de ska: 11 februarie 2014 - 10:52
#2 bleunightdanger
  • 10.070 Mesaje:
Inregistrat: 17-martie 04
  • Model:Corolla 1.4 D4D
  • Motorizare:Auris 1.2T CVT
Scris 12 februarie 2014 - 01:39
Mi se pare cel mai misto Mercedes al ultimilor 20 de ani!
#3 pejte
Scris 12 februarie 2014 - 10:20
Cel mult cel mai misto mercedes "normal", ca altfel...  :lol:
  • 1
#4 andrei041
Scris 12 februarie 2014 - 11:23
Alaturi de noul A si mie mi se pare cel mai reusit din gama accesibila.
#5 ska
Scris 12 februarie 2014 - 02:06
A, C, S, CLS, G. cam astea-s.
#6 andrei041
Scris 12 februarie 2014 - 02:26
G'ul nou e iarasi misto, insa parca nu prea m'as vedea in asa ceva. Asa si cu S'ul, chiar si CLS'ul. De aceea sunt cu o treapta mai jos in preferinte fata de A si C
#7 mol
  • 6.444 Mesaje:
Inregistrat: 17-august 05
  • Marca:M3 Power by...
  • Model:Gillette
  • Motorizare:1,5 v
Scris 12 februarie 2014 - 02:37
...pai aduce a BMW...:)
#8 bleunightdanger
  • 10.070 Mesaje:
Scris 12 februarie 2014 - 05:43
No way. Este fix opusul seriei 3
#9 pejte
Scris 13 februarie 2014 - 12:16
Pentru mosi, extrem de confortabila, sta jalnic pe sosea si nu trage deloc?  :D
  • 1
#10 oaspetele
Scris 13 februarie 2014 - 07:19
N-as baga mana in foc ca nu trage si sta rau pe sosea.
Cat despre faptul ca e confortabil, tu esti asa mai masochist ??
:D
#11 mecea
  • 4.582 Mesaje:
Inregistrat: 27-decembrie 09
  • Marca:Tractor
  • Model:Modern
  • Motorizare:Fumigen
Scris 13 februarie 2014 - 07:51
pai daca e fix opusul seriei trei ? finisata exceptional si cu dinamica de k.k.t, cel putin asa afirma dom' redactor.
#12 oaspetele
Scris 13 februarie 2014 - 08:27
n-am condus beamwe.
#13 kng
  • 1.818 Mesaje:
Inregistrat: 25-aprilie 12
  • Marca:Skoda
  • Model:Octavia 2
  • Motorizare:1.9 TDI
Scris 13 februarie 2014 - 11:50
Cum pot unii sa compare 2 masini, fara macar sa fi condus una din ele, nu mai zic sa te fi suit in ea. Dar tot romanul se pricepe la fotbal, la politica si la masini :D
  • 1
#14 oaspetele
Scris 13 februarie 2014 - 02:55
la mine te referi ?
#15 ska
Scris 13 februarie 2014 - 02:59
io cre ca o sa fie destul de dinamic. poate nu ca benveu'. ca benveu' nu-i niciunu'.
#16 Frank SF
Scris 13 februarie 2014 - 08:10
Aveam articolul și aici,  pe blog:
http://www.garajul.r...rcedes-clasa-c/
Vă invit și va rog mult sa mai intrați și pe blog.
Referitor la acest c-class, îmi place design-ul sau general,  elegant,  dar seamănă prea mult cu noul S class.  În plus nu îmi place abundenta de crom,  de plastic sau nu,  de pe majoritatea modelelor Mercedes,  nu îmi place soluția cu sistemul Command cu ecranul ca un iPad adăugat ulterior (la A și CLA se sparg masinile și se smulge ecranul ala hoții crezând ca e un iPad),  nu îmi place ca de atâția ani ei vin tot cu 2.2 CDI de 170 CP,  ca sunt prevazute puține versiuni cu 4matic (C200, C400 și C250 Bluetec) și ca nu va avea un diesel cu 6 cilindri pt a concura cu seria 3. Iar rezervor de 41 litri?!  Bine,  probabil ca va avea opțional rezervor mărit la 50 litri contra cost.
Cu condiția de a bifa opțiunea suspensiei adaptive....
#17 mecea
  • 4.582 Mesaje:
  • Marca:Tractor
  • Model:Modern
Scris 13 februarie 2014 - 08:45
la mine te referi ?
unde dai si unde crapa, omu se referea, zic eu, la inventatorul pedalei de acceleratie wireless, de fapt bag mana in foc pentru asta.
nu stiu cum e noul c class, de fapt nu stiu nici vechiul, ca in clasa asta doar de 190 m-am atins, dar cert e ca actualul treiar in configuratii comparabile, stock vs stock, etc, este considerabil mai putin hardcore ca ala vechi si mult mai confortabil decat te-ai astepta de la un zembe, cel putin asa mi s-au parut mie, insa nu le-am condus una dupa alta, asa ca frank ar trebui sa spuna mai multe aicea
320d este insa totusi o masina incredibila, ma refer la cum merge, mie personal mi-a placut mult, si nu cred ca are rival in clasa, dar asta tine de gusturi, in plus cheala e sa zicem ok la pret, configurata decent devine de domeniul absurdului.
#18 alex230ro
  • 3.936 Mesaje:
Inregistrat: 07-ianuarie 04
  • Model:325ti aka caaazaaan
  • Motorizare:2.5
Scris 13 februarie 2014 - 08:50
stric de cazane vorbind cica aia de benve au pus botu la afirmatia ca E90 e prea rigida and shit si la F30 au mai taiat una alta.cat despre Mercedes habar nu am am mers cu un 190 si era misto restul am stat in dreapta deci nu ma pronunt.
#19 Frank SF
Scris 13 februarie 2014 - 10:58
masina mea cu suspensie stock e mult mai sportiva pe drum virajat decit F30 cu suspensie stock care e chiar woobly, si asta fara sa fie realmente inconfortabila, e perfect ok de trait cu suspensia, mai ales cu roti pe 16 inci cum am eu. Singura chestie e ca la anumite denivelari mari se aude cite un zgomot puternic din suspensia care parca percuteaza si rupe masina in doua, dar in realitate nu se intimpla nimic (verificat masina pe dedesubt dupa primele incidente din astea).
la actuala, daca vrei o tinuta de drum sportiva, trebuie musai luata suspensia adaptiva, caz in care pe sport este inca surprinzator de confortabila chiar cu jante pe 18 inci, iar ca tinuta de drum e ceva mai sportiva decit a mea, insa sa zicem cam la 90 % din performantele celor mai sportive versiuni (M Pack) ale E90.
In general BMW a antamat o migrare a noilor sale modele mai spre confort, pe motiv ca asa cere piata. E o transformare care vine bine la X5, mai putin la 3ar. Masinile ramin destul de polivalente, dar cel putin la seria 3 suspensia adaptiva devine un must pt o tinuta de drum sportiva (nu e un must la X3 sau la Seria 5).
http://www.garajul.r...une-si-ratiune/
"Si totusi, modelele cele mai sportive ale predecesorului E90 reuseau sa fie si mai dinamice pe un drum virajat(si nu vorbim aici de M3). F30 este superior insa din punct de vedere al pachetului combinat, al compromisului intre tinuta de drum sportiva si confortul la bord. E ca si cum BMW a pierdut 10 % din sportivitatea tinutei de drum pentru a dubla confortul (chiar si in conditiile echiparii cu jante mari, de 18 inci, precum modelul testat de noi) – oricum acei 10 % nu vor fi resimtiti decit de cei mai sportivi dintre piloti."
Revenind din off-topic, la noul C class, Merc ofera in premiera in clasa, suspensia sa airmatic, adica chestia pe care probabil stie sa o faca cel mai bine dpdv al unei rulari confortabile, dar nu stiu in setarea sport cit de sportiva va fi. De vazut si cum va fi masina stock. E pacat dupa mine ca au renuntat la suspensiile Agility Control, care in esenta este solutia amortizoarelor FSD de la Koni si care reprezinta o solutie mecanica foarte eficienta pentru o suspensie adaptiva:
http://www.koni.com/...w-does-it-work/
Aceasta postare a fost editata de Frank SF: 13 februarie 2014 - 11:00
#20 bleunightdanger
  • 10.070 Mesaje:
Scris 14 februarie 2014 - 12:06
320d mi-a placut si mie extrem de mult. De fapt motorul este senzational si pe alte modele.
Referitor la C-Klasse sunt convins ca stie sa fie suficient de dinamic. Oricum sportivitatea este interpretata altfel la MB. Ei nu pun accent pe senzatii ci pe eficienta.
Noile interioare mi se par superbe, materialele sunt etalon, singurul minus fiind la designul displayului. La A-klasse nu m-a deranjat prea tare, te obisnuiesti. Dar Command-ul este inca departe de i-drive de la Bmw.
#21 Frank SF
Scris 14 februarie 2014 - 11:13
In sensul ca iDrive e mai bun, mai intuitiv, right?
#22 bleunightdanger
  • 10.070 Mesaje:
Scris 15 februarie 2014 - 01:12
I-drive e mai ergonomic si vine cu un display mai mare ai cu o grafica mai misto.
Ca functii sunt la fel.
#23 Frank SF
Scris 16 februarie 2014 - 09:54
Eu nu prea inteleg ce vrei tu sa zici cind spui ca MB pune accentul pe eficienta... Care eficienta? Repet, de nu stiu cita vreme ei defileaza cu 2.2 CDI 170 CP, la consumuri BMW-urile si chiar si unele Audi-uri bat constant Mercedes-urile fiind in multe cazuri si mai rapide, so?!
Mercedes-urile au alte atu-uri de partea lor, interioarele mai bine finisate, la anumite modele un compromis confort tinuta de drum foarte bun, insonorizarea foarte buna...
Aceasta postare a fost editata de Frank SF: 16 februarie 2014 - 09:57
#24 bleunightdanger
  • 10.070 Mesaje:
Scris 16 februarie 2014 - 05:30
De multe ori MB-urile mi-au consumat mai putin. E drep ca BMW sta foarte bine la acest capitol, dar asa a fost dintotdeauna.
Personal MB-urile mi se par mai echilibrate, fara a fi agresive in mod inutil :) Sa nu mai vorbim de 4Matic, care mi se pare cel mai eficient sistem din tripleta Audi-Bmw-MB.
#25 mecea
  • 4.582 Mesaje:
  • Marca:Tractor
  • Model:Modern
Scris 18 februarie 2014 - 08:53
De multe ori MB-urile mi-au consumat mai putin. E drep ca BMW sta foarte bine la acest capitol, dar asa a fost dintotdeauna....
detaliaza putin te rog, bmw-urile stau foarte bine aicea sau mb-urile consuma mai putin ?
...4Matic, care mi se pare cel mai eficient sistem din tripleta Audi-Bmw-MB.
foarte interesanta treaba, poti sa ne spui te rugam care au fost sistemele testate, si implicit ce versiuni, si care au fost conditiile de testare ? in poligon, la munte, ce traseu de offroad, etc orice detalii tehnice ar fi binevenite
