auto recalls (probleme si chemari la service)
306 replies to this topic
#1 mike.omega
    v.i,p.
  • 3.310 Mesaje:
Inregistrat: 30-aprilie 03
  • Marca:Dacia
  • Model:Liberta L
  • Motorizare:1.4 62CP
Scris 06 septembrie 2004 - 09:01
New recalls for Audi and VW?
Volkswagen Extends Engine Warranties
Volkswagen and Audi are extending the engine warranty on two of their most polular models because of a sludge problem with the four-cylinder, turbocharged engine.
The vehicles are the 1998-2004 Volkswagen Passats and the 1997-2004 Audi A4s, both of which share the 1.8-liter engine
Volkswagen of America and Audi of America are part of Volkswagen AG.
In a letter being sent to owners, the automaker said it is extending the warranty because some consumers have complained of engine problems resulting from oil sludge.
Sludge is a thickening of the oil because moisture and contaminants build up and break down the oil, causing it to gel. That may reduce the flow of oil through the engine, causing excess wear or a failure.
The extended warranty is for eight years starting when the vehicle was new. There is no limit on mileage. The warranty covers subsequent owners.
To have repairs covered, owners must be able to prove that they changed the oil according to the automaker's recommendation, which is six months or 5,000 miles.
"An engine failure can cost consumers thousands of dollars. Volkswagen and Audi did the right thing by taking responsibility for oil sludge in their vehicles," said Clarence Ditlow, executive director of the Center for Auto Safety, a consumer group in Washington, D.C.
Volkswagen is not alone in having a sludge problem. In 2002 Toyota announced it would cover 3.4 million engines for eight years and unlimited mileage. Those were 3.0-liter V-6s from the 1997 to 2002 model years and 2.2-liter four-cylinder engines from the 1997 to 2001 model years.
Volkswagen began sending the notices to owners recently, spokesman Tony Fouladpour said Friday.
http://www.autospies...81&categoryId=1
Pot sa pierd in viata tot! Nu imi pasa! Ma ridic la loc!
#2 the1
Scris 08 septembrie 2005 - 07:33
Da, scandalul este intr-adevar mare si sunt si multe procese. Au si murit cateva persoane in urma unor incedii provocate de acest defect.
#3 jaffar
    member
  • 3.922 Mesaje:
Inregistrat: 02-iulie 03
  • Model:Z4 2.5si + R1200GS
  • Motorizare:218 HP + 110HP
Scris 13 iulie 2006 - 02:43
Why would Toyota issue a recall designed to make vehicles less safe?
http://money.cnn.com...ecall/index.htm
#4 MikeTekRacing
Inregistrat: 22-august 03
Scris 13 iulie 2006 - 03:25
lipit cu un topic mai vechi
#5 the1
Scris 14 octombrie 2006 - 01:08
Honda recalls 3000 Civics
12 October 2006
� Engine may stall or fail to start
� Corrosion blamed for recall
� Cars built in May and June affected
Honda is recalling more than 3000 Civic small family cars over fears the engine could fail to start or suddenly stall and fail to restart.
The manufacturer has found that water left in the fuel tank during testing procedures could cause corrosion on electrical components of the fuel pump system. Fuel pressure could suddenly drop as a result and leave motorists unable to start their cars.
Engines could also stall on the move and then subsequently fail to restart.
In all, 3036 cars built in May and June this year are potentially affected by the defect. Owners are being contacted by Honda with the offer of free checks and remedial work.
#6 the1
Scris 07 noiembrie 2006 - 01:12
Recalls: Alfa Romeo and Volvo
02 November 2006
� Alfa 147, Alfa GT and Volvo S80 affected
� Clutch could fail on the Alfa Romeos
� Volvo cabin heater can short-circuit
Alfa Romeo and Volvo are recalling more than 6000 cars for safety checks.
Alfa wants to inspect 5355 147 hatchback and GT coupes after discovering a potential problem with the clutch. A clip that secures the pin between the clutch cylinder and pedal can become detached and leave the car without clutch operation.
Volvo wants to inspect 714 new S80 executive cars for checks on the cabin heater. The manufacturer has found that the system may have a short circuit which drains the battery and can, in rare cases, lead to a fire.
Volvo will disable the cabin heater as a temporary measure until the root cause of the problem can be identified.
Affected Alfa Romeo vehicle identification numbers
ZAR93700005156078 to ZAR93700005298888
ZAR93700003185703 to ZAR93700003777404
ZAR93700003254498 to ZAR93700003334641
ZAR93700005155403 to ZAR93700005260743
Affected Volvo vehicle identification numbers
00000000000000568 to 00000000000013569
#7 the1
Scris 03 ianuarie 2007 - 12:24
Wiper woes: Mercedes-Benz recalls 130,000 vehicles in Germany
After a rough few years full of significant recalls, Mercedes-Benz appeared (or appears, depending on your perspective) to be getting its act together by successfully addressing its quality issues. The automaker just announced a major recall in Germany involving 130,000 vehicles windshield wiper motors that could be defective. While one recall a return to quality does not ruin, neither does it help. The recall in question only affects A- and B-Class vehicles, as well as C-Class wagons built between May 2005 and May 2006. Some may consider defective wiper motors a minor issue, but a recall by definition is significant, and in this case one could imagine a dark and stormy night where being without wipers could be deadly.
[Source: Automotive News - Europe]
#8 masterblaster
  • 6.376 Mesaje:
Inregistrat: 30-octombrie 05
Scris 11 februarie 2007 - 03:12
Honda is recalling 43,335 Civic hybrids for a possible voltage converter problem. The problem vehicles, which were manufactured between September 2005 and September 2006, could have engine failure if the voltage converter causes a short circuit. Owners of the recalled vehicles here in the United States, which consist of most of the volume, will be notified by mail. There have been no reported accidents as a result of this problem.
Honda also announced a Japan-market recall of 72,597 Elysion minivans due to defective sliding door locks.
#9 adrian_r5
  • 6.094 Mesaje:
Scris 08 septembrie 2007 - 11:30
1600 de autoturisme Logan din Brazilia, chemate in service
Renault retrage 1.600 de masini Logan de pe piata braziliana pentru verificarea sistemului de frinare.
Renault va retrage in service 1.623 de autoturisme Logan comercializate in Brazilia pentru verificarea pedalei de frina cu scopul de a vedea daca luminile de frina functioneaza corect. Renault do Brasil, filiala locala a constructorului francez, mentioneaza ca vinzarile pe piata braziliana au ajuns la 2.114 de unitati in luna august, fata de obiectivul lunar stabilit la 1.500 de unitati. Modelul Logan a fost lansat in Brazilia in luna iunie. Renault a anuntat ca intentioneaza sa mareasca productia de autoturisme Logan la unitatea din Brazilia, la 60.000 de unitati in anul 2008, fata de un nivel de 40.000 de unitati, prevazut pentru acest an.
In primul semestru al acestui an, vinzarile Logan pe toate pietele au totalizat 158.913 de unitati, in crestere cu 28,4% fata de valoarea raportata la sfirsitul lunii iunie 2006. Renault a inceput in acest an productia automobilului Logan in Iran, India si in Brazilia. Logan este fabricat in sapte state si vindut pe 55 de piete, sub marcile Renault si Dacia.
http://www.cotidianu...Hash=7d578b4cfa
#10 adrian_r5
  • 6.094 Mesaje:
Scris 05 februarie 2008 - 08:48
Volvo recheamă 82.000 de maşini
Producatorul de masini a anuntat sambata ca a rechemat 82.000 de masini din cauza unor probleme care ar putea afecta buna functionare a grupului propulsor.
Masinile vizate apartin seriilor S40 si V50, fabricate intre 2004 si 2006, cu motoare in 5 cilindri pe benzina si care ar putea avea un defect la modulul electronic de comanda a pompei de combustibil.
Majoritatea masinilor au fost comercializate in Statele Unite, Suedia si Germania. Reprezentantii Volvo nu au facut nicio declaratie privind costurile la care se ridica acest proces.
Saptamana trecuta, compania a fost amendata de un tribunal francez datorita unui accident mortal care a avut loc din cauza unei defectiuni la sistemul de franare.
http://www.capital.r...amp;cauta=volvo
200.000 de euro amendă pentru Volvo
Constructorul de automobile Volvo a fost amendat astazi cu 200.000 de euro dupa un accident mortal in care si-au pierdut viata 2 copii, iar unul a fost grav ranit.
In data de 17 iunie 1999, pe o sosea in panta din oraselul francez Wasselonne, o femeie a pierdut controlul volanului unui Volvo 850 TDI break care avea cutie automata, din cauza faptului ca sistemul de frana nu a functionat.
Tribunalul care a judecat cazul a declarat ca Volvo este "principalul responsabil pentru accident" datorita sistemului de frana " insuficient de fiabil si eficient."
Compania Volvo a contestat ipoteza unei defectiuni tehnice ale automobilului.
http://www.capital.r...ru-volvo/106929
Aceasta postare a fost editata de adrian_r5: 05 februarie 2008 - 08:50
#11 adrian_r5
  • 6.094 Mesaje:
Scris 20 februarie 2008 - 11:48
Porsche recheamă 19.000 de unităţi Cayenne
Producatorul de masini sportive de lux Porsche a anuntat ca va rechema aproximativ 19.000 de unitati ale modelului Cayenne dupa ce s-a constatat un defect cu potential de incendiu pentru automobil. Mai precis, o conducta de combustibil se poate desprinde si atinge de blocul motor al SUV-ului de lux. In mai multe cazuri, s-a descoperit ca acea conducta avea urme de frecare din cauza contactului cu blocul motor.
Compania a anuntat ca sunt vizate 18.856 de masini vandute intre 30 noiembrie 2006 si 18 ianuarie 2007, in tarile in care compania din Stuttgart este reprezentata oficial prin dealeri autorizati.
Porsche a declarat ca operatiunea are in loc in urma a 5 reclamatii depuse de catre clienti, fara sa fi avut insa loc accidente. Reparatia in sine va fi suportata gratuit de compania germana, care a precizat ca operatiunea nu dureaza mai mult de 40 de minute in service.
Luna trecuta, Porsche a anuntat ca se asteapta sa vanda 20.000 de unitati ale modelului Cayenne, pana in luna iunie.
http://www.capital.r...p;cauta=porsche
#12 oaspetele
Scris 07 martie 2009 - 03:43
"Toyota recheamă 1,35 milioane de maşini
Autor: Valentin Vioreanu
Publicat: 28 Ianuarie 2009
Vizionari: 1385;
Producatorul japonez de automobile a anuntat astazi ca va rechema 1,35 milioane de automobile din toata lumea, din cauza unor defectiuni constatate la centura de siguranta, la teava de esapament, sau la ambele.
Rechemarea vizeaza 525.000 de unitati din modelele Vitz, Belta si Ractis din Japonia si 833.000 de unitati diin modelul Yaris Hutchback si Yaris Sedan din Europa din America de Nord.
Modelele rechemate au fost fabricate intre ianuarie 2005 si aprilie 2008.
Sursa: Le Figaro "
Articolul e aici: http://www.capital.r...ini-116120.html.
#13 cata69
Scris 07 martie 2009 - 03:46
prea grav nu poate sa fie, ca mureau toti pana acum din 2005.
#14 oaspetele
Scris 07 martie 2009 - 03:54
l-am pus ca poate citeste unu cu yaris.
#15 cata69
Scris 07 martie 2009 - 04:12
f bine
#16 oaspetele
Scris 12 martie 2009 - 09:33
Lexus a rechemat in service 214.500 automobile in SUA
In ciuda reputatiei Lexus pentru calitate, marca de lux a Toyota a fost nevoita sa faca o rechemare in service in Statele Unite ale Americii.
Reputatia Lexus pe una dintre cele mai mari piete de desfacere din lume a fost afectata de o conducta de combustibil care are putea sa fie afectata in timp de coroziune si sa curga. Se pare ca aceasta problema ar putea sa apara doar daca se foloseste etanolul pe post de carburant.
Desi nici un client nu a avut o problema de acest gen cu Lexus-ul sau, Toyota a descoperit pericolul potential cu ajutorul unor martori luminosi din bord care semnalau probleme. Recall-ul afecteaza gamele GS, IS si LS, ale caror modele au fost produse intre 2006 si 2008.
sursa : http://www.automarke...-sua-17852.html
Desi e doar preventiv, recall-ul acesta ne demonstreaza ca nimeni nu este infailibil.
#17 Relu
Scris 12 martie 2009 - 09:46
Dupa parerea mea, demostreaza seriozitatea fabricantului Toyota !
#18 DanCld
  • 932 Mesaje:
Inregistrat: 31-august 06
  • Model:Auris
  • Motorizare:1.6 VVT-i 124cp
Scris 12 martie 2009 - 09:58
La Toyota exista un site cu toate rechemarile: http://www.toyota-te...u/TomsCabs.aspx
La modelul meu se potriveste o rechemare legata de niste saibe la coloana de directie (8K3E-480); cand i-am sunat pe indivizii de la Inchape ("Toyota Romania") tanti de la telefon parea pierduta complet, i-am dat indicativul rechemarii si numarul meu de caroserie, a zis ca revine. Alta data! Nici la Toyo Motor nu au fost mai receptivi :) A, stati, faza - m-au sunat de la Inchape sa imi aminteasca sa fac revizia; asta a fost la o saptamana dupa ce facusem revizia la Ruse :cunaooooo:
Aceasta postare a fost editata de DanCld: 12 martie 2009 - 09:59
#19 oaspetele
Scris 12 martie 2009 - 10:34
asta se subintelegea.
#20 maximus
    BattleStar Galactica
  • 999 Mesaje:
Scris 12 martie 2009 - 08:45
daca e facut ca urmare a cererilor nhtsa-ului eu zic ca nu. Pana la urma la ei e o socoteala economica: daca costul rechemarii e mai mic decat costurile legale date de nefacerea recall-ului nu il vor face. Citeam pe autoblog, ca toyota e in mijlocul unui scandal, legat de un recall la un truck, caruia i-au facut recall abia dupa nu stiu cati ani, dupa ce au aflat de problema, desi au fost oameni morti/raniti din cauza chestiei asteia..
Capul lui Moţoc vrem!
#21 adrian_r5
  • 6.094 Mesaje:
Scris 30 septembrie 2009 - 12:09
Toyota recheama aproape patru milioane de masini, dupa ce au existat cazuri in care pedala de acceleratie s-a prins sub covorasul de pe podea
Toyota recheama pentru verificari circa 3,8 milioane de masini marcile Toyota si Lexus in SUA, dupa ce au existat cateva cazuri in care masinile au accelerat puternic si necontrolat din cauza ca pedala de acceleratie s-a prins sub covorasul de pe podea, scrie Detroit News. E cel mai mare recall al Toyota, iar autoritatile insarcinate cu siguranta in transporturi sfatuiesc soferii sa scoata de urgenta covorasele din masina.
Totul a pornit de la un incident petrecut in august, cand patru oameni au murit in San Diego dupa ce un Lexus a fost implicat intr-un accident la peste 190 km/h. Chiar inainte de coliziune unul dintre pasageri sunase la 911 sa raporteze ca pedala de acceleratie s-a blocat. sursa
#22 Relu
Scris 30 septembrie 2009 - 12:18
Daca ar fi fost in Romania, aia de la 119 ar fi raspuns ca merg prea tare......
#23 berkut
  • 2.629 Mesaje:
Inregistrat: 07-aprilie 03
  • Marca:HANDEI
  • Model:6 viteze
  • Motorizare:1994
Scris 30 septembrie 2009 - 12:55
e greu sa tragi de covoras ...
imatur pentru ca am subaru.
#24 VIPER
Scris 30 septembrie 2009 - 01:15
Da, e greu sa faci asta in mers mai ales cand covorasele moderne au sisteme de prindere care ar trebui sa le fixeze.
#25 Relu
Scris 30 septembrie 2009 - 01:33
Bine ca in manual scrie ca tre sa inchizi usa inainte de plecare, altfel ar curge americanii din masini.....
